Question:
Isn't there more to it than that? I mean... Doesn't the TwEECer have firmware that "interprets" what is stored within the TwEECer slot and converts it to the machine language used in the Ford EEC?
Doesn't the TwEECer actually add to or subtract from what's in the EEC firmware?
For Example:
Let's say that the Ford EEC commands 20 degrees total timing at no load and 3000 RPM. You tell the TwEECer that you want 25 degrees at that load and RPM. Doesn't the TwEECer extrapolate the difference and add code to obtain the desired effect?
Please don't take my questions the wrong way. I truly do not know what the answers are and am wondering.
I have seen software out there that will convert a TwEECer tune to a chip for use on a Ford EEC through an EPROM burner but they were always "add on" chips that you plug into the back. I have not seen anything yet that could be used to replace the EEC CPU.
Daggar-
I am a Tweecer user, and by no means an expert on 'HOW' the tweecer works.
But, the impression I get is that the .ccf file that the tweecer creates, contains new settings that are loaded into the stock eec, which replace the factory .bin file settings.
I haven't gotten the impression that the tweecer 'adds' or 'subtracts' from the factory .bin.
But like I said, I am only a user not an expert on the 'how' part.
For clarification,
The TwEECer is the only EEC tuner that does not create a new tune in a .bin format. The TwEECer actually creates a .ccf file, which is a proprietary format exclusive to the tweecer.
PCMX, Moates, etc, all create new tunes in the .bin format.
I remember reading this thread earlier this year, and it's good to see it revived.
From what I understand now, the MegaSquirt is the best
shrug: if not only
) option for controlling such an unusual and custom EFI system.
For controlling a system that resembles a factory Ford system however, it would still be effective to use one of the EEC tuners available.
Just my thoughts...
jason
