I used several different ecu's to tune my own fox Mustangs (A9L, X3Z, CBAZA for a 2.3L n/a, to name a few), with either TwEECer or Moates QH. I don't mind using these moving forward, but since I will be tuning both a v8 and a 4 cylinder in the near future (hopefully), it will benefit me to have these 2 cars be as similar as possible.
I like Megasquirt because of price, and from what I understand, system flexibility (I have questions below on this however).
What I don't like about megasquirt is trying to figure out the differences between systems. There isn't a really good detailed technical spec sheet/comparison between the MS1/MS2/MS3. It is all written as hi-level advertising... I think I am figuring out what I need to know though, it's just slower than I had hoped.
My background: I work in Materials/structural test for a commercial aircraft manufacturer. I have written several versions of software applications for thermal control (PID based), data analysis/reporting, and monitoring of test rig activity. I have tuned my own 408w as well as an N/A 2.3 running at first on a CBAZA ecu, but later switched to CZAJL (both are v8 ecu's). I messed around with Arduino stuff as well, but nothing more than exploring/playing.
I don't mind writing my own code, calibrating sensors, etc, as long as I don't have to use Ladder Logic
. That is part of the fun of messing with control systems
So, that was long-winded... here are the questions I have right now...
Can I customize inputs to fuel and timing? For example, could I average 2 intake temperature inputs to correct fuel, instead of basing fuel adjustments on a single temperature input?
Can I create my own code for something like a fan controller, using a PWM for variable fan speed, and switch to relay control when desired (programmatically)? I would otherwise build this with Arduino, but would prefer it integrated with the ECU.
Could unused Fuel injector outputs be repurposed? Can the output hardware/channel be reprogrammed by the user? In other words, .if using an MS3 on a 4-cyl car, could I use the other 4 injector channels for control of electric water pump/fan? Can I write my own code for control of these channels? If so, what programming language would be used?
When using the GPIO kit for output control, what programming language is used?
. That is part of the fun of messing with control systems So, that was long-winded... here are the questions I have right now...
