Cobra MAF
Well I am using a 93 MAF housing with my stock 89electronics and my car runs great and runs good track times for my elevation.
Anyone have a clue as to why? I would like to know if my choice for a MAF is holing me back. BTW, I switched to the 93 MAF housing after having no luck with a 76mm C&L unit.
PJB said:
Will the '94/'95 sensor just plug into my '92 harness?
Also, if I use the '94/'95 sensor and the adapter will it work with my fenderwell cold air intake or will there be a clearance issue?
I think the plug on the 94-95 meter are the same as the Fox plug, so you shouldn't have to do any wire splicing.
You won't really know if your going to have clearance or fitment issues with the cai until you fit it together.
Too many variables in there.
However, it should work.
jason
What you are describing is a stock setup. The 89 MAF and 93 MAF are the same. Both 55mm.
The sensors are the same between these applications as well.
jason
Curse said:
Sorry I am using a 93 Cobra MAF housing.
Oooopsss
I should have caught that in your sig.
Why that works, I don't know. It is possible that the AFR is off, and you don't know it.
Have you had the car tuned?
You need to check the adaptive adjustments being made by the EEC.
Most likely the computer is working pretty hard to get the AFR as close to stoich as it can. It may not even be getting to stoich.
Joe (Stang&2birds) mentioned this earlier in the thread.
You don't really know if it works, unless you check the adaptive adjustments being made by the EEC.
What is the part number on the MAS you are using?
Probably F1ZF or F2VF or similar.
jason
stang&2Birds said:
PMAS - ~$300.
Or, get a 94/95 70mm MAF and a 70mm square mount to round adapter.
Here's a picture (~1M) of the 55mm Fox MAF, the 90mm LMAF (requires a chip), and the 70mm 94/95 MAF.
http://www.veryuseful.com/mustang/tech/tmp/mafs-fox-LMAF-94.jpg
Here is a 70mm mounting adapter that I and others have used.
http://www.kustomz.com/cat3.html
70MM Adapter TR70 44.95
Other companies used to also offer the adapters. As of TODAY, this is the only 70mm mounting adapter that I know of.
If someone knows of ANY others, PLEASE let me know!
Found this on ebay
http://cgi.ebay.com/ebaymotors/94-0...ryZ33710QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
says 5.0, but looks to be small. Found one for a "v6" that has a 3.5" openeing which measures the same as my stock one. Ordered it, i'll report back and let you know if it's a POS or even fits.
so the 93 cobra mass air sensor just the sensor can not be used in a C&L meter with the factory A9L 89-93 lx gt computer correct? so the cobra maf sensor need to be used with the cobra computer? is this correct? thanks jason
The 93 Cobra MAF needs the 93 Cobra EEC or a Tweecer/custom-chip.
If you use a C&L, it's a cr*p shoot!!!!! Ford customs tunes EACH sensor to a unique MAF body. It MUST be done because of tolerances in the electronics and the MAF body. ANY EE/CS/ME (Elec Engr, Comp Sci Engr, Mech Engr) will tell you that (if they have a clue, I've meet some Engrs that I would have flunked out if there were in any class that I taught. :)). Any 3rd year EE/CS/ME student should also know that.
Some people "get away" with swapping the sensor and using a C&L by "luck". It's like playing the lottery and buying ~5 instant tickets.
1) You may get nothing (the EEC can't properly adjust for that sensor/body combo)
2) You may get some money (the EEC can SEMI-adjust enough for the new MAF/Sensor combo)
3) You may win more money (the unique MAF/sensor combo is very close to stock)
BTW: I have my MS in CS/EE. And, I'm "3/4th's" an ME (I don't need an ME degree, so I took the "important ME classes" when I was an undergrad and grad student). I've been professionally designing and architecting this "control/response stuff" for over a dozen years. And, I taught it for many semesters. So, you can believe what I say, or listen to others. That's your choice. I'll tell you what I know and why. I don't have the time/desire to argue with people that don't have the background.
My buddy has an EE degree and a CE degree. He's a professional EE, and has been for a number of years.
He thinks you are WAAAAAAAY too emotionally invested in this whole thing. Chill out...it's good for the heart. My C&L works great. Most people I have spoken with say their C&L works great. I have no driveability issues, no funny idling, no funny surging, no black smoke, no detonation. Oh, I also have lots and lots of power.
Everyone is entitled to their opinion. However, lots and lots of people stop listening to opinions when they are spouted in a rude, unruly, and pretty unsophisticated way. You've managed to do all three. I know you are trying to help, but you'd be a hell of a lot more helpful if you learned some tact to go along with your mastery of Ford MAF systems.
Have a grand day!
The only way to do that would be with a custom tune.
That is correct.
The X3Z computer and the Cobra MAS (an F1SF, if memory serves). are specific.
With that said...
Any 70mm Ford tube should work fairly well with the MAS from a 94-95 Mustang (F2VF, I think).
So, the 70mm Cobra MAF should work well on a Fox (A9*) computer, if a 94-95 Mustang MAS is utilized.
As Joe (Stang&2Birds) has mentioned though, there is a risk assumed any time you mess with the MAF/MAS combo. Accuracy of the air measuring device is critical. The computer has some ability to adjust, but that ability is limited.
Any Ford 70mm MAF tube paired with a 94-95 Mustang MAS should function fairly well with an A9L/A9P/A9* computer.
I hope that helps clear things up,
jason
i hope when you say 93 you mean 93 cobra... otherwise you did nothing. the 94/95 MAF's electronically speaking plug right in however one side is square so you will need to modify to get it to work.
It hasn't been said yet so just to clarify for anyone looking for the 94/95 maf swap, the maf can come off a 94 or 95 GT OR V6!! just FYI
