Help with P1311 code.
98gtr
14
My CEL came on a few weeks ago and is giving out this code. I don't understand what this means. I looked it up on the web and I'm getting opinions ranging from bad front 02 sensor to faulty MAF sensor, bad fuel pump, dirty injectors, etc. Can anybody help me out with this? My car idles normal except for slight seconds everynow and then. It seems like it wants to hesitate when its wet or raining sometimes nothing too bad though and doesnt quite have the take off speed at low rpms.
If it is driving bad when it rains like that, it is more than likely the o2 sensor. It would be the front passenger side o2. You can test it to make sure by swapping the two front o2 sensors. If the code follows the o2 then the o2 is bad. If it doesn't follow the o2 I'd start checking injectors. I personally just go ahead and replace it if it is fairly old.
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean
first thing you need to do is read the long term + short term fuel trims for both banks and get the total fuel trims.
If you see something like
Longterm1.. 20 % + shortterm 1.. 10 percent then bank one has a total fuel trim of + 30 percent
then what you want to do is compare the total fuel trim on bank one to the total fuel trim on bank 2..
If bank 2 is normal ( total fuel trim under 12 percent either positive or negitive) then your concern could be a misfire, exhaust leak before the sensor or a bad sensor itself.
If bank 2 has a high total trim but has not set a code then I would lean more towards a bad MAF or vacumm leak.
Can you get to it from under the hood or do you have to jack the car up?
it's most likely the sensor itself.. as Jstreet said I would just replace that sensor.
02s11 is the top 02 sensor on the passenger side right near where the mid pipe connects to the exhaust manifold.
If you have access to a real scan tool then you can look at live data and look at the stuff I pointed out.
