A week ago my heater core started to leak in the car, so I bypassed it by placing a tube between the two hoses that normally went to the heater core. Had no issues with the car running hot.
The tube sprung a leak so I cut one of the heater core hoses to make a U and connected each end to the ports coming out of the engine that are supposed to go to the heater core.
Since doing that, when I am at a stop the temp will rise from the N all the way to M and almost seem to want to go further. The fan will definitely kick on and maybe take it down in between the O and R. Once I take off and the air hits the engine and it returns to the N in normal. The only time it really heats up is when I am at a stop.
Things I have tried and using:
-Completely burped the system
-Checked and made sure the fan is coming on when it needs to
-Using stock type 195 temp thermostat.
-Checked port where I bypassed the heater core for leaks, none.
I am looking for advice on what to check and find out if by bypassing the heater core this is normal behavior or not.
