If I did it I would get a Novi 1000, its good for about 2 tenths more than the Vortech, and I would also get a new pull so that it would boost at 10PSI...I am confused as to what the 8" crank does for it...is that bigger or smaller than stock? Thanks for your help, I think I will install it myself if I do go down that road...but I got to some thinking tonight and have another question.
If I put on a S/C i can't do nitrous because I will blow a head gasket correct? And if I put on a S/C I most likely won't do H/C/I because of the fact it costs just as much as the S/C did and also it would be harder since there is a blower to uninstall.
I thought about spraying it right now with a 125 shot and then saving up enough for the H/C/I and I think that is the route I am going to go...
It is my understanding that the max shot you can go with is a 125 wet shot, or could I get by with a 150 ajustable wet? I should be able to install the kit myself right? As far as installing an H/C/I goes, i've done an intake on my friends 350z and it wasn't that bad...but if I installed just the intake they would have to take it off and reinstall it anyways when they put the heads on so it would be completely pointless correct? Also what is a better system for delivery? Through the air intake tube or EFI Plate?
Thanks for any further help!
EDIT: If I spray it with a 125 shot how big injectors will I have to buy? I am thinking of just picking up the Lightning MAF/Injectors but I am afraid of going too big because they will kill my MPG wont they?
