Question for those with CNC Machined Aluminum Battery Trays
afast93stang
1,407
North Texas
This is the one I jut got for my Optima Battery, any suggestions on how you installed it in the engine bay?
For mine I used an aluminium L bracket I found in my friend's shop and use the power steering hose bracket hole as the mounting place on the frame. It moved the hose out a tad but nothing to be conserned with. Once I found where it sat even I mocked it up and drilled holes in the base of the mount and countersunk them so the base and L bracket could be bolted together. On the other side my optima mount uses internally threaded aluminium rods so I just drilled holes in the fender and throughbolted the rods through the aluminium base from the inner fender. This is the type I have. http://cgi.ebay.com/ebaymotors/Bill...tegoryZ33575QQihZ008QQitemZ180070501768QQrdZ1
Just be careful when bolting the positive on.
Kevin
i though Optima batteries didnt need a battery box, just a bulkhead (or a notchback) to separate ti from the passenger compartment? aren't the Optima's already sealed?
I don't truely know the answer to that, but imo it's just not worth the risk of the track official saying no go. I used the taylor kit, which i got very very cheap, if i did it again, i would use the blue moroso box.
