Well, I took the rear end out of my car after ordering numerous parts, ie. bushings, diff. brace ect ect ect. My main reason for pulling it was to fix the leaking differention cover.
My question now is what oil is best to put in the rear end? I'm in no hurry to put it back together, so I have time to order it if it's something the local parts stores don't stock.
Also, my stock stock adjuster seems to be worn. The clutch doesn't seem to disengage, so I put the car in 1st with the car off and pull up on the clutch pedal which adjusts the clutch. Immediately after this, the car shifts perfectly. But after 1 or 2 easy shifts, the clutch cable needs adjusted again. My question is this, which adjustable quadrant do you guys recommend. Thanks.
