Here’s my problem:
I recently had 4:10 gears installed on my auto 2001 Gt. Along with the gears, I had a tranny cooler the J-mod done.
Everything was fine except I had to adjust the speedo and shift points with a handheld predator that came with the car when I bought it.
Here’s the issue – When I start from a slow roll (between 5-10mph) and go WOT, the 1-2 shift will not occur at the set rpm point (4600 rpm’s). It will hold the 1st gear until it hits the rev limiter for 1or 2 seconds and then shifts to 2nd. If I start from a complete stop, the 1-2 shift occurs at approx. 5400 rpm’s (indicating the 4600 rpm point is working well.)
The car didn’t do this before the gears and j-mod were installed. I’m worried that the j-mod got messed up somehow. I didn’t do the install. The guy who did the gears did both at the same time.
- I have done searches for the past month on all the mustang sites and tccoa.
-The fluid levels were checked and are good.
- The tranny fluid was changed when the j-mod was done. (Less than 500 miles ago)
- The car has obo 35k miles on it
Thanks in advance for your help guys.
