dsg03bullitt
- Jul 25, 2006
- 2
- 0
- 0
Whoa.....yea i ran a 13.532 and that is close to your time......but with your mods you should suck the paint of off my car....
A/F is at 13.0, dyno was a dyno jet. dou you think my shocks/springs may be hurting me?
see top posttry to play around with your shift points and also what is the altitude of the track.
you should be more in the 109 trap range with that much hp.
Yea, I guess so. State capitol is having a test n tune next Friday. I hear they have a well prepped track. Who knowshmmmm that close to sea level and that looks like a pretty good rpm to shift. thats weird i only dynoed 232rwhp and am close to you in the 1/8th traps with 3.73s. o well i guess you could even try and different track as well.
you should be running 12's
As Spock would say illogical for 6000 RPM! With your 315-35-17rear tires a 4.10 and 4 th gear at 5700 is 106.26 MPH, 5800 is 108.12 MPH, 5900 is 110.MPH, 6000 is 111.85 MPH. Now if you are coming through the 1/4 mile at 5700 your MPH make sense since it is an average at the end of the 1/4. That also means you are down on HP. Are you able to do any data logging during your runs?
See middle finger.
Careful...I see a problem coming if you don't tone it down.See middle finger.
Ricky...shifting can make all the diff in the world. Your peak is around 5500 so shifting at 5800 would be best. A shift light would do the trick. I had runs that were all within a tenth of a second but my traps ranged from 98mph to 103. I still haven't had any good runs since to get a feel for where I should shift but you can see where trap times and speeds can vary. I still have some ET to gain with my best trap speed so more practice is needed. Same goes for you.
Thanks, I think my main issue is the driver, its obvious, the dyno graph shows the hp is there, I just need to practice putting it down! Geaux Tigers!![]()
Oh...get some DR's...they are good for at least 2 tenths. PM me next time you go and we can meet up at the track. Our car club (see sig) gets together and goes quite often.
