Head swap in an 86 w/ e cam
PonyGrl420
450
SC
I have an 86 with an e cam (converted to maf) I want to change the heads but Im worried about clearance. Ive read the the trickflows are ok with the flat topped pistons, but will I have any clearance issues with the e cam? Also do all the trickflow heads fit or just certian ones?
Are there any other heads that i can use?
Thanks
Thanks
I have a 86 with the stock heads and flat top pistons with no valve relief. I am using aluminum 1.6 roller rockers. And I also have the E303 cam that I have not installed because I am afraid of valve interference. Are you using the same configuration as me? I just want to make sure this would work OK.
Thanks.
Pablo.
Thanks.
Pablo.
Pablo, with 86 heads the e cam will clear.
PonyGRL is talking about different heads and an e cam, which may not clear.
