Computer and Exhaust Cut-Outs
93gtmustang
524
43
49
I'm having exhaust cut outs installed for when I drag race.
How long will it take the computer to adjust from full exhaust to open exhaust after I open them up at the track?
Thanks
Where are you putting the 'cut outs' ???
As long as the cut out is AFTER the O2's, it will have no impact on the computer.
How much power do you expect to gain by doing this?
jason
They are going to be installed just before the cats, after the O2 sensors.
I'm not putting them on for a power gain, just to save my cats. I rattled the heat shields loose last year and had to have them welded.
The cats can add a little resistance to exhaust flow.
However, if you have newer cats which are appropriately sized, I doubt you will see any increase in power. Not enough to notice anyway.
Bypassing the cats to run richer at wot is a decent idea. As long as the O2's are in the loop, it won't cause any issues with the computer.
Be sure to mount the 'Y' in the exhaust as far from the O2's as possible, to prevent fresh air contaminating the exhaust sampling.
Let us know how it works out...
jason
bypassing the cats would help, but you still need backpressure, o2 sensors are useless at WOT anyway, I am sure it would be faster with the stock stuff unless you have 4.10 or better gears a large cam, and a high compression high RPM motor. Just a guess though.
The term 'Back Pressure' kinda pisses me off.
'Back Pressure' is always bad. It restricts the flow of gasses. There is no benefit to 'Back Pressure'
What you guys are describing is actually a result of runner length tuning.
The same principles apply to intake runner design.
I think the major concern for the question originally posed will be 'Will the exhaust pulsations even out, before they exit the shortened exhaust system?'
Not sure if that made things better or worse.
jason
The term is correct, but I agree that it may be a *little* misleading. :)
You do want *some* back-pressure! Consider back-pressure being like Velcro on the back of a moving truck. If it's moving "faster" than you, then you get can get pulled along (to a point!).
Actually, The exhaust gasses create a *vacuum*. So, it's more like a loose vacuum line in your engine and a piece of paper. If the paper is close enough to the loose vacuum line, the loose vacuum line will pull the paper towards it. However, if the loose vacuum line is too small or too far away, then that *vacuum* won't have any effect on the paper.
An exhaust system works in a similar way. A PROPERLY sized exhaust will keep the pipes hot to promote air velocity, AND
o the *vacuum* created by the exiting previous exhaust pulse will result in better evacuation of the spent gases from the cylinder
o the *vacuum* created by the exiting previous exhaust pulse will result in more fresh air into the combustion chamber/cylinder
o help/pull the other exhaust pulses out of the exhaust
o and so on.
An exhaust that is too small will present a restriction.
An exhaust that is too big will not provide any extra help in moving the exhaust gasses.
An exhaust that is too "just right" will result in better evacuation of the spent gases from the cylinder, more fresh air into the cylinder, and more power.
Yup, more fluid dynamics junk. :)
I'm running a Ford Racing 5.0 b-cam crate motor. I have bbk shorty headers and flow master exhaust.
Will my car run the same, worse or better with the cut outs open at the drag strip?
I really don't want to install the cut outs if it is going to make my car run worse.
Thanks
I really think it will not help, maybe if you move the cats back as far as possible so you have a longer piece of pipe before the cut outs to help improve the velocity of the exhaust flow then maybe, if there were a gain I dont think it even be noticable.
backpressure is bad. what you are looking for is exhaust exit velocity. which is good. backpressure would be a restriction in the exhaust causing more turbulance and less flow. exhaust velocity is free flowing exhaust gas through the right size tubing with no restrictions. you can test this with different size straws. lol. too small and its hard to blow through it (restriction) too big and you run out of breath too fast. just right and you can see what the difference is. im pretty sure this will be hard to understand to most people, since i keep confusing myself reading it...:rlaugh:
o and so on.
Yeah, I just think the term is misused, and therefore misunderstood.
I think using the term backpressure leads one to think that a smaller diameter primary will add power, simply because it is a restriction.
Obviously, this is not the case.
What is actually happening is...
The primaries feed off the high and low pressure waves in the other primaries. Pressure is highly influenced by area, so diameter and length of the primaries need to be considered.
But you understand what I'm saying better than I do :p
Is there a "Fluid Dynamics for Dummies" book? :scratch:
If not, is there something else you could recommend?
I have looked a couple of times for fluid dynamics material that is theory based, rather than math based.
:Word:,
jason
Thanks
I don't think you will see much of a difference. Probably not enough to be worth the monetary cost :shrug:
Just don't stick the cutout immediately after the header flange.
Get as close to the cats as you can.
Maybe Stang&2Birds can elaborate a little more...
If you move the cats too far from the heads, they will never get hot enough to work effectively. They will plug up pretty quick.
Leave the cats where they are...
jason
I think using the term back-pressure leads one to think that a smaller diameter primary will add power, simply because it is a restriction.
You have a good handle on what's involved.
I wish! Unfortunately, a *lot* of Fluid Dynamics is very heavily based on advanced calculus. MEGA PUKE! I took grad level advanced fluid dynamics courses and materials courses. Even while I was in grad school for EE/CS, I was hedging my bets with my Mech Eng courses. :) If, for what ever reason, EE/CS didn't work out for me in the "real world" work place, I could go back and get my BS in ME by taking only a few courses. Also, my grad school adviser had his _first_ PhD in Mathematics, and our lab had the University-made Mechanical Arm/Robot. So, he was happy to help me out with the PITA mathematics in fluid dynamics, statistics, etc.
That's why I like and know about things like the TPS, MAF, air bag, ABS, EFI, electronic control of mechanical systems, and so on.
Amazon.com has a number of books. BUT, be *very careful* about buying any used books from amazon. MANY times, the low cost listings are for pdf versions of the SOLUTIONS, NOT the actual text book. I know, I got screwed buying the "solutions" when I *thought* I was getting a great deal on a $100+ book.
