The term is correct, but I agree that it may be a *little* misleading.
You do want *some* back-pressure! Consider back-pressure being like Velcro on the back of a moving truck. If it's moving "faster" than you, then you get can get pulled along (to a point!).
Actually, The exhaust gasses create a *vacuum*. So, it's more like a loose vacuum line in your engine and a piece of paper. If the paper is close enough to the loose vacuum line, the loose vacuum line will pull the paper towards it. However, if the loose vacuum line is too small or too far away, then that *vacuum* won't have any effect on the paper.
An exhaust system works in a similar way. A PROPERLY sized exhaust will keep the pipes hot to promote air velocity, AND
o the *vacuum* created by the exiting previous exhaust pulse will result in better evacuation of the spent gases from the cylinder
o the *vacuum* created by the exiting previous exhaust pulse will result in more fresh air into the combustion chamber/cylinder
o help/pull the other exhaust pulses out of the exhaust
o and so on.
An exhaust that is too small will present a restriction.
An exhaust that is too big will not provide any extra help in moving the exhaust gasses.
An exhaust that is too "just right" will result in better evacuation of the spent gases from the cylinder, more fresh air into the cylinder, and more power.
Yup, more fluid dynamics junk.
