- Oct 11, 2006
- 17
- 0
- 0
Ok so my car (95 GT) has been having this problem for a little while and seems to just be getting worse. Sometimes I would start the car up and everything would seem fine, it would drive fine, no hesitation or missing, and other times it would buck and miss like crazy.
Its got the the point where I can barely drive the thing. Also when I'm at idle, like waiting for a light or coasting down the driveway, the car will just cut out and stall. After it stalls it has NO problem starting back up, but if it idles for too long it will stall again and again.
The car is not pulling any codes, I even took it to Ford and they couldn't diagnose the problem (only spent 3 hours on it, but thats when I pulled the plug on them).
They said that it could be the stator, but they are not 100% sure and they can't guarantee that replacing it will fix it. They also keep on asking me if the car has been chipped, and I have no idea and neither did the previous owner.
Parts that have been replaced recently: Plug wires, fuel pump, ignition coil, cap, rotor, plugs and fuel filter about 18k kms ago.
Ford's diagnoses was:
Report for vehicle running rough
Stalling (can start up right away) at idle.
Road test
Spits and Sputters
NGS Self tests pass
PID data fuel pressure test: 32 psi
Sample check okay
Power balance spark duration
Erratic ignition system: System test
Spark duration and advance dropping off
Timing check 10 degrees try new coil, cap, rotor
Repair wiring to ignition coil
Same check plugs
Possible ignition problem
Road test
Spits and Sputters
NGS Self tests pass
Sample check okay
Same check plugs
