No blinkers, which fuse?
Zero Signal
2,633
Tucson, AZ
Well recently my girlfriend's 93GT had a problem with battery corrosion and I ended up fixing that. In the process, the 8ga. power cable to the sub amp literally just fell off since it corroded through. For some reason, ever since then the blinkers just don't work. They don't come on at all :shrug:
I replaced the blinker unit and checked all the fuses in the fuse box under the dash. They all check out with the continuity tester. Is there another fusebox I don't know about? Maybe one in the engine bay? I know my 95 has one under the dash and one next to the driver side strut tower. I did notice that I have to mess with the left steering column lever to get the headlights to come on at all. COuld it be a problem in the steering column?
John, by-chance did you accidentally replace the hazard flasher? It's very easy to find at the fusebox, whereas the TS relay is buried in the dash (in one of several locations).
Good luck.
