Has anyone CUT their smog bracket off?
gcomfx.com
3,690
Republic, MO
Has anyone CUT their smog bracket off? Updated with PIC!
Updated with pic!
I'm getting everything ready for the engine swap. I removed my smog pump a while back. While taking the accessories off the engine, I just noticed how HUGE and heavy the alternator/smog bracket is. :shock:
Running the shorter belt on my setup has worked fine over the years. So my question is... has anyone CUT their smog bracket off? Or is there an aftermarket bracket I can buy that ONLY holds the alternator? :shrug:
I might as well save some weight and space if I never plan to put it back on the car right? :D
Well because of my supercharger backet, I don't have that issue nor do I want to cut it, but I don't have AC anymore so I cut that bracket down just like your asking. Just another thing to help clean up the look and save a little weight.
I believe I'm running the 89.5 belt. It's been a while so I may be off.
Mine is very close to that. I have the actual belt number written down in my car. It varies about an inch depending on which underdrive pulleys a car has, and how many/if any. :nice:
BTW - bracket is now cut.... Going to clean it up and paint it with alumi-lite as soon as it warms back up around here. :D
You'll be fine. I cut mine 5 years ago b/c I didn't want to run an eliminator kit and no problems.
Thanks... a little late to turn back now. :D
