thanks, JT and Grady.
cleaning the PIP seems like a quick/easy thing to do, so i will do that in a while. can you tell me exactly where it is, though, please? i've douched everything else (iac, tps, maf, connection to coil, etc) in some pretty good electrical cleaner, and i still have a bit left for the PIP.
my buddy just got a new msd dizzy, so we're gonna try it out on my car to see if that could be it--just to cross that out if it isn't.
thanks for the info on the 511, Grady. i'll clean up the connection today w/ a qtip + electrical cleaner and try to get it to go away.
there is, in fact, a small exhaust leak coming from the headers. i'm giving the copper gasket time to get settled, tightening the header bolts every other day. it's gotten significantly less worse w/ each tightening, so i figure it'll clear up after the next couple.
the K values you're referring to, though: do those show up w/ the tweecer? once i know where to check those, i'll switch sides w/ the o2's and see if the readings switch, too.
thanks, gentlemen.
