missing under 1500 rpms
v8tiger
88 Gt with mods are Gt40x, e303, cobra intake. roller rockers, bbk shortys, and MAF conv.
Just installed them, and now it misses when the engine is cold really bad. But when it warms up, its only before 1500 rpms. timning is around 12.
and why would there be oil on the last two ports of the intake when you take the upper off?? The gasket is wet of oil just on the last two holes.
Happen to me the other day in the coupe.... I was pissed! But it was my Air to fuel mixture and the computer setting! At lease that was my problem... Hope it helps some! - JJ
how do you check if the air to fuel mixture is correct.
I had a terrible miss before whent he lower intake was leaking vacumme. But i fixed that, and i didnt think that it was still leaking.
Do you have any codes?
HOw is the cold idle enrichment function? Do you have to hold the gas pedal down when the engine is cold? Has the ECT been checked for calibration?
Good luck.
The reason you might have oil is becasue if you are running the chinese (replica) version of the cobra intake manifold the baffle is not large enough to keep oil from getting into the intake. There are plenty of threads concerning this issue, just search cobra intake.
is the oil hurting anything?
And also. when i checked for a vacumme leak today, i couldnt find any.
I set the timing to 14-15 and idle to 900. It idles way better. And my TPS is at 1.10
i had it set at .98 before i raised idle.
the check engine light is not on.
i will check for codes tonight.
so now i checked the codes and it says Code 66. MAF input voltage too low.
So i went to the parts store and tried a new Sensor and it did the same thing.
Also i noticed with the sensor unplugged it runs the same.
