Any Fox Body's with 03/04 SVT Wheels?
'01 Cobras (and 99's, same thing) were 17x8 and came polished. The 03/04 premium GTs had the same rim, but chromed.
Anyway, here ya go:
I'm pretty sure you'll have no issues because they're not 8" up front. If anything you might need the larger 91-93 front spats to accept the 17" wheel, but that may not be a problem at all.
The ones you posted are '03 Cobras. Not 99/01 Cobras / 03/04 premium GTs. Similar but different at the hub area and in width.
I have no idea the offset, but they're whatever the stock specs are for the SN95s.
they are a 17x9 with +24mm offset.
do you recall the offset on yours? it appears they are set in a little bit more than some of the other brands ive seen. correct me if im wrong, :shrug:
That's not an '01 SVT wheel. That's the 03/04 SVT wheel. 17x9"
May have some fit issues with it. Definitely will need the Sn94 conversion. Mark 7 rotors won't cut it but even so, the front wheels may stick out.
I edited the thread title for you to see if anyone with those wheels can offer some input.
Here's mine, dont mind the front ride height. the front end was off the ground for about 2 months before these pics were taken, so it has to settle again...
I havent gotten a chance to drive it since I put the wheels on, so I dont know if they will rub or not, but just from looking at it I think i will be fine on the front wheels, and the rear will clear no problem once I flip the quad shocks. The tires are 255/40/17 up front and 275/40/17 in the rear.
edit; the wheels are originals off an 03' Cobra, so they're machine finish, not chrome/silver/polished. just FYI.
