P1443.. What does it mean?
Since I purchased my GT, the check engine light has been coming on and off. It usually only stays on for a few minutes every 2 weeks. I went to AutoZone while the CEL was on, and they gave me this code.. P1443. It says on the reciept they gave me, "Evaporative emission control system control valve." First of all, is this that bad? Second, where is this so called valve? If it has something to do with the midpipe, I'm just gonna fix it by an o/r pipe with some MIL eliminators. So, help me please!
yeah, they reset the code for me but i hope it doesnt come back. I noticed that my gas cap doesnt feel like it locks in too tight, but it still seems tight enough to not cause a problem....
It could be tight but not sealing properly...
From another thread:
svttech said:
it's for the purge flow sensor voltage. the purge flow sensor voltage is part of the evap emmisions system.
ford pc/ed 1996 said:
Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
Damaged EVAP canister purge valve.
Damaged PF sensor.
