Granatelli MAF Problems
crags90gt
I just bought a Granatelli 90mm MAF, and ever since I installed it I cant get my car to idle. Ive tried resetting the timing to about 15 degrees and setting the idle up to about 800 rpm and then resetting the tps at .98, and then it will idle pretty good, but when I shut the car off and then start it again I have the same idle problems. I'm not really sure on what to do at this point cuz I dont have a lot of knowledge with efi systems so i need some help with this one. I also bought FMS injectors which I have not installed yet and someone told me that it would probably fix the idle problem after I install them. My engine is pretty much stock except for a mild cam and its bored .30 over and I have installed a cold air intake. If anyone can help, PLEASE DO! Thanks in advance.:hail2:
If you still have your old maf swap it and see if it idles right, if it has the same problem with the original maf then its a differnt problem, could be IAC, ACT sensor or an ignition problem. If it ends up being the maf from Granateli I would take it back from where ever i got it. Some mafs are cold air tune-or regular tune, thats what im aware of and thats what the company had displayed in there adds, what type is yours? I dont know if there would be much of a difference and cause a idleing problem.
I'm thinking along the same lines as whtpny on this one. My guess is that you're not getting enough airflow across the MAF element because the velocity through the meter is too low. Try swapping back to a stock meter if you're still running 19lb injectors, or see if anyone has a meter you can test with that's rated for the same size injectors you're using.
Welcome to :SNSign:
It sounds like you installed the new MAF, but didn't install the new injectors?
This would cause major issues with the fuel metering...
The MAF is calibrated for the injector size, correct?
jason
Like mentioned above^^^
If you bought an aftermarket meter calibrated for any injector larger than stock but are still running the stock injectors you will have problems without question.
If the MAf is calibrated for the new injectors i would install then and go from there. If the MAF if calibrated for stock (19#) injectors I would remove the MAF and replace it with the stock unit.
If that fails I would be sheck the voltage at the maf
the MAF is coldair tuned and it is calibrated for 19lb injectors and the car does idle fine with the stock meter installed and I called Summit racing today, which is where I got the MAF, and they said that there is no reason why the car should idle bad and they think that it could be a bad MAF. So they are going to send me a new one and see if that works. But after reading what you guys have to say I dont think it will fix the problem. I had the idea that it was too big and that there wasnt enough air folw at idle so hearing a second opinion is always good.
Thats amazing.... why in the HELL would they make a 90mm maf for 19#ers??? if your car moves enough air to need a 90mm maf then sure as HELL need bigger injectors!! this make no sense to me. The MAF is way too big for a stock setup even if it was calibrated to 19#ers
