What was the problem that you purchased the ignition system to cure?
What ignition system did you purchase?
Did the item you purchased solve your problem?
Did the item you purchased create any other problems?
If you could change something about the aftermarket ignition system you purchased, what would it be?
So when I was getting the heads swapped with a pair of Thumpers the problem revealed itself. On the top of the heads, and top of the pistons there was a "white fuzzy" type material. Im guessing it happened from low octane fuel and sitting around for a year or so.
