Stock H pipe removal?
Warrior 102
231
Macomb MI
Hey guys,tomorrow me and my buddy are planing of removing the stock H pipe of his car and installing the of road one,can anyone tell me how hard is to do this,what is the most difficult thing about that?
Please post your experience with this, and any tips if you have for this job...
I appreciate your help.
Thanks........
Start by hitting the all the nuts with penetrating lube. You will need a 12'' extension, a swiveling socket end, and I think a 15mm deep dish socket. A breaker bar may also help if the nuts are siezed up. The nuts on the passenger side manifold are the hardest to get at....you will need the swivel for these. Be careful when taking the midpipe to manifold nuts loose. If they are taking a lot of torque to loosen them after you have them broke lose,lube them up more and be careful so that they dont break the studs off the manifolds. You will also need M.I.L. sensors to plug into your rear O2 sensors so you dont get a code since you are installing an offroad midpipe.
wont be that bad, the upper passenger bolt to header is hardest. I just used a 3/8" 12" extension w/ a universal swivel and some muscle - a 1/2" drive would be much better. Should be an hour to and hour and a half job. takes me 15-20 mins now, lol (w/ the aftermarket one, the stock one weighs like 60 lbs w/ the 6 cats on it)
The PB Blaster is a must. A medium dish socket (18mm) is what I used. The regular shallow socket won't be deep enough for the stud to clear and the deep dish won't hit the wheel well on a 1/2 inch drive wrench. Not sure about a 3/8 but you want something you can get some torque on. Otherwise it is a fairly easy job. I can pull mine and replace it in 30 minutes now.
Got one for my tranny removal. When I get the cash I want to get a set. Its 3/8 drive impact 13mm. Tho you will want a deep socket. A U-joint socket will only go to so much of an angle then bind. Like CV joint axles, your driveshaft, etc. A swivel will have no problems at any angle because of its ball in socket design. Dont confuse it with a wobble witch only moves a little bit.
http://cgi.ebay.com/ws/eBayISAPI.dl...MEWN:IT&viewitem=&item=260066012008&rd=1&rd=1
