the smog can be eliminated without a tune or anything and wont throw codes or anything its as easy as removing the pump and getting a shorter belt...then you have to remove the pipe that runs behind both heads...you must plug both of the holes in the heads and this can be done with a 9/16 bolt you probley wont be able to find a 3/4" 9/16 bolt so you will need a 1" with some washers.. then you will also need to plug the pipe that goes to the h pipe...pinch it and weld it or use something like a jb weld.... if you want to eliminate the erg you will need to have a tune to take the function out of the computer but if your building a 331 you will already need a tune anyways ...as far as deleting the egr it is very easy and cheap. first off you will need to block off the egr where in connects to the elbow you can get a egr delete plate or a 351C fuel block off plate works great.. and can be easily purchased at an auto parts store... now for the header to be blocked you also have options... first one is buy the expensive caps...second is cut your tube since you wont be using it any more and take the original fitting off and reuse that...but theres a hole in it where the pipe was...all you need to do is put a penny in there it blocks it and seals great so that method only costs you .01 and lastly since your building a engine if you already dont have headers just order ones for a 86-93 they are identical without the fittings in them...so you wont have to cap anything
