Finally got a Dyno done...ok numbers I guess.
Finally got some time on a Dyno at a local shop. The guy at the shop said there was not much left to be had without more mods.
Did 3 runs with weather at 62 Degrees and around humidity 10%
Max HP 242
Max TQ 285
A/F hung around the 13 area.
What do you guys think about these numbers with my Mods?
Scanner cut off bottom, but I painted the RPM values in.
~K
Nice number! But if you were are upset about not making more...just look at how much you've spent in ICE and how much that coulda gone towards a blower hehehe :D
:nice:
Actually all my audio, etc (ICE) was left over from years ago when I showed my explorer. Most of its about 6-8 years old.
Unlike most people, I started with the suspension and brakes and am just starting to work on the engine. Not sure if I want to stay N/A or go to FI....
Next mods are gears, UD Pulleys with a bigger Alt, Mid-pipe, LT headers. Then maybe start on the internals.
Overall it seems my numbers are average, and that is what I was hoping for.
FYI, I am using the canned predator tune.
Run 1 was the canned tune with timing maxed out.
Run 2 the tuner changed something (don't know what he changed)
Run 3 we took some timing out to see what would happen.
Seemed nothing we did make any real changes to how the car ran.
Should I look into a mail order tune or stick with the predator canned one? Or maybe finally go to SCT?
~K
Pretty good numbers man. I'll post up my dyno graph when I get it off of my laptop. :D
I made max 199.58rwhp / 269.72rwtq, and that was with an AFR of around 11:1 when it hit high RPMs. :barf: My peak power was at 4300rpm :notnice:
I suggest that my numbers aren't bad for being pretty freakin' stock. Suspension is next for me, then JLT CAI, Steeda UDP, and then Accufab Plenum/TB combo, then a dyno tune :banana:
Do you think I'll be hitting the 240rwhp range then? Just don't forget...my car is still NPI. :nonono:
