Now you're adding conditions. If you're gonna add "proper welding" as a condition in the equation, then whoever installs the LMM seat brackets can add optional weld points to make it even stronger and beefier. We can add conditions to the comparison all day but that wouldn't get us anywhere.
Conditions? Like proper installation? Well how else would someone put the MM seat brackets together? Glue?
My point is... between a single piece and multi-piece item, I prefer the single piece. You get better support without the added installation requirements. I didn't say the multi-piece construction will weaken the structure.
You said, "I can just imagine how fragile that would be compared to a bracket made from a single piece." Hmm, not verbatim, but to me these sound like you are saying essentially the same thing..correct me if I'm wrong.
I'm not a structural engineer but I like the LMM design better. I like the fact that they are lighter. I am not convinced I need heavy gauge steel beams to connect the two subframes. One guy locally showed me his custom made SFCs and they were twice as large as the MM ones and probably weighed 100 lbs. Is it overkill? I think so. We're not trying to make a single frame like the ones on trucks. We're just connecting the two frames to reduce flex. Where do we draw the line of what's overkill? Who knows.
Well, I, for one, (and I'm not in the minority) have faith in the MM products, particuliarly these SFCs and I believe they know what is overkill and what's not overkill more than LMM. Did you realize that MM actually was the first to call these things 'full length subframe connectors'? If you don't know the history of MM, please do yourself a favor and take a quick read of their 'about us' webpage. This company is serious about Mustang Performance. They race what they sell and sell what they race. They are automotive enthusiasts as well as engineers and designers. To me, this is like having a friend in the racing business. Face it, LMM simply buys stuff and sells stuff...they are a retailer, that's it. And there is nothing wrong with that. But to me, the choice of products is quite simple. Do you want the Walmart brand or do you want the race shop's brand. (And sometimes. for some things the Walmart brand is OK...but not for suspension.)
It's been a while but I believe the LMM ones have two supported bends. The MM ones have one. Does that impact the overall effect on the car? I don't know. I know it's a cleaner fit.
Wrong - MM's have two, supported by welded plates.
Cleaner fit? Well, maybe that's your observation because of how short the LMM subs are, in effect making them 'tighter' to the chassis? What's not 'clean' (other than the obvious..be nice, bro) about this install?
Prefitted for the Mustang is NOT good? I don't think I'm understanding your logic here.
The Mustang is just like any other Ford (or any other American made car) - the fit and finish leaves a lot to be desired. While the seat bracket may leave just 1/32" of gap on your car, don't be surprised if the next car has 1/8" gap...now can you see where you'd benefit from a custom installation?
