After doing a "search" I've pretty much concluded from other threads that I'm experiencing some sort of a timing issue with my motor after doing the cam swap.
When I turn the motor over all I get is a popping coming from the carb. I've tried advancing & retarding the distributor ( as far as the vacuum advance will let me anyway) & still no results - no indications what so ever of it wanting to start...
I've double checked that the #1 piston is on the compression stroke several times by turning the motor over until I feel pressure in the spark plug hole & then re-installing the distributor with the rotor aimed at that piston. Is it possible that I could STILL be out a 180*?
Also - I installed new plug wires & was wondering if I possibly messed up their order going back on the cap? The firing order that I'm using is 1-5-4-2-6-3-7-8. The reason I'm second guessing their order is there is no point of reference on the distributor cap indicating where the #1 wire goes. Should there even be one?
Can anyone help me identify where or how I could determine that? BTW - Its a MSD Pro-Billet dist if that makes any difference.
Thanks in advance...
