Uninstalling a T5
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
I need to know what the steps for the uninstall of a T5 is, what tools will be needs, and average time it takes to pull a T5 out.
Thank you :SNSign: !
45mins - 3 hrs removal time...45 if everything goes right, 3 hours if bolts are uncooperative. here's a quick walk through:
DRAIN FLUID!!!
remove shifter, 4 bolts (not always necessary to remove entire shifter, atleast handle though)(5-10mins)
unhook o2 sensors
remove midpipe..2 bolts each side at headers and flowtubes, 8 total(20-30 mins depending on how rusty your bolts are)
remove driveshaft using 12point 1/2 socket, 4 bolts(5-10 mins)
put jack under transmission to support it
unhook all sensors and such from transmission
unbolt transmission from x-member, 2 bolts
remove transmission x-member, one bolt and nut combo each end (1/2" socket and wrench) (3mins)
remove 4 bolts mounting transmission to bellhousing(5-10 mins)
now all you have to do is pull the transmission back from the bellhousing making sure the input shaft clears the bellhousing before you drop it and you're done!
a hint for removing the driveshaft bolts...with the rear of the car in the air, spin the back wheel until the bolt on the driveshaft you need to get to is exposed. times are based upon having the tools ready and handy. don't remember exact tool sizes either...sorry. hope this helps!
i just saw your post about pull it yourself yards so i'm assuming you're doing this at one of those. as far as tools, take an assortment in metric and standard, some extensions, and maybe even a breaker bar. i always lug around my "throw away" tool box that i keep in my trunk to anything i have to do like that. just a bunch of random tools i KNOW i've used on my stang. lol
DRAIN FLUID!!!
unhook o2 sensors
I'll just take all the tools, and if I don't some of them... Better to have it and not need it, than to need it and not have it. :shrug:
Thanks for the info :nice:
This includes the clutch, but the basic plan is the same.
Before you get started, buy a Chilton or Haynes shop manual. You will need it for the bolt torques and patterns.
1.) Jack up the car front and rear, use jack stands to be safe.
2.) Put a 2x4 wood block under the engine oil pan to support the engine. Jack it up slightly. This prevents damage to the motor mounts when the transmission mount is removed. The oil pan is plenty strong for this purpose. Disconnect the negative battery cable. You will need a couple of extensions and a ½” swivel socket to remove the top starter mount bolt, which is accessed from the front and under the headers. Leave the starter wiring connected unless you plan to change the starter at this time.
3.) Label all the wiring for the transmission before disconnecting it. Disconnect the O2 sensor cables at their connectors. Disconnect the speedo cable by pulling it straight out of the VSS sensor, or by removing the bolt that holds the VSS sensor in place. If you remove the VSS sensor, zip bag & tag it along with the bolt that secures in place.
4.) Remove the drive shaft, the rear bolts are 12 MM. You will need a high quality 12 point wrench for this: do not skimp or you risk rounding off the bolt heads. A helper to step on the brake to keep the drive shaft from turning will be helpful. Use your foot to apply pressure to the wrench to loosen the bolts. Note the yellow markings in the drive shaft and write down their alignment.
5.) Put a catch pan under the rear of the transmission to catch the fluid when you slide the yoke out of the transmission. I recommend that you drain the transmission at this time. There is a pair of pipe plug filler ports on the side of the transmission. Use the lower plug to drain the fluid.
6.) Inside the car, remove the shifter boot and then remove the shifter handle
7.) Remove the H pipe & rear trans cross member. The chassis to cross member bolts are metric, you need a 15 MM & 17 MM socket or wrench. Note the direction and size of the humps on the cross member and write it down. Inspect the rear transmission mount and replace if damaged.
8.) Remove the transmission. You will need a long extension & a universal joint with a ¾” socket. A transmission jack or a helper is almost a must have unless you can bench press 75-100 pounds with ease.
8.) Remove the clutch cable cover and pry the throwout bearing arm forward enough to slide the cable off.
9.) Remove the bell housing using the long extension & a universal joint socket. Note how the throwout bearing rides it the throwout bearing arm, and which end faces the clutch pressure plate. Write it down or make a drawing if necessary.
10.) Remove the bolts securing the pressure plate to flywheel. Be sure to label & zip bag them separately from the rest of the parts. Work in a star pattern to reduce stress on the pressure plate mounting tabs.
11.) Remove the flywheel mount bolts, as you will need to either replace or re-surface the flywheel. Be sure to label & zip bag them separately from the rest of the parts. Tap the locator dowels out of the flywheel with a 1/4" pin punch. Zip bag them together with the flywheel bolts.
12.) Inspect the transmission input shaft where the throwout bearing rides. Replace it if worn or damaged.
13.) Inspect the throwout bearing, throwout bearing arm and ball pivot stud for wear or damage.
14.) Inspect the rear oil seal for leakage and replace if required.
15.) Remove & replace the pilot bearing. A puller borrowed or rented is helpful here. A wood block will be used to drive it home.
16.) Install the flywheel, noting that the bolts are an odd pattern, and it only lines up one way so that all the bolts go in easily. Torque to specs according to the shop manual.
17.) Install the clutch disk with the hub springs facing the rear of the car. Use a pilot tool available for $3-$4 from the auto parts store to line it up.
18. Install the pressure plate, be sure to use the pilot tool prior to tightening the pressure plate bolts. Torque to specs according to the shop manual. Remove the pilot tool when you are finished torquing the bolts.
19.) Install the throwout bearing on the throwout bearing arm, noting the direction of the bearing and it mounting in the arm.
20.) Install the bell housing. Torque to specs according to the shop manual.
21. Install the transmission, have the transmission jack or helper at hand to lift it into place. Watch out that the stub of the shifter does not tear the shifter boot. Some 7/16 bolts with the heads cut off can be used to help support the transmission as you slide it home. It may be necessary to press the clutch pedal to get the transmission to slide the last ½” or so. Remove the guide studs if you used them & torque to specs according to the shop manual.
22.) Reinstall the clutch cable by prying on the throwout bearing arm. Replacement of the stock cable or quadrant is recommended if you haven’t already done so. With adjustable cables, both nuts go on the back side of the throwout bearing arm.
23.) Reinstall the rear crossmember & transmission mount. Torque to specs according to the shop manual.
24.) Reinstall the wiring and speedo cable or VSS sensor if you removed it.
25.) Reinstall the drive shaft, slide the yoke in place. Align the rear yellow markings and install the bolts. A helper to step on the brake to keep the drive shaft from turning will be helpful. Use your foot to apply pressure to the wrench to tighten the bolts.
26.) Remove the jack from under the engine oil pan.
27.) Refill the transmission with the proper fluid. T5’s use Dextron ATF, Tremec 3550’s use GM Synchromesh. There is a pair of pipe plug filler ports on the side of the transmission. Use the top plug as the filler port.
28.) Adjust the clutch cable according the manufacturer’s instructions if you have an adjustable cable & quadrant. Set the emergency brake and use the drag it provides in order to determine where the clutch starts to engage. You should have 1 -1 ½” free play from the top. The cable will not have any slack and will have some preload on it when properly adjusted.
29.) Re-install the H pipe and remaining items.
30.) When you have visually checked all the bolts, fittings and other parts are present and not interfering with each other, then take the car down off the jack stands.
31.) Be prepared to put the car back up on the jack stands to adjust the clutch and tighten up any loose items found after the test drive…
