FIrST TIME AT THE TRACK
greenbud89
9
what up ? i have an 89 hatch with a rebuilt 302 woth gt40 upper and lower trickflow twisted edge heads 1.7rr 24lb injectors b 303 cam 3:73 gears 70mm tb and i ran a 14.5
ok now i have really tight suspenion that is good for the street but too stiff for the track plus my tires were dry rotting but my best time was a 14.5 how bad is this ? what should i be running ?
i also had a set of cobra rims on that couldnt have helped
will slicks break my stock rear ? i heard it will but not too sure .. and with slicks and some suspension work what kinda of numbers do u think im looking at ?
i also have a kenne bell s/c to put on but as it is not im not hookin up
your **** is messed up somewhere. the ET isn't your issue really. I've seen people screw up in a Z06 and run a 14. Your MPH shows you are way down on horsepower, Stock 5.0's will run upper 90's at high 13's and low 14's.it is your mph (93!). You have a big problem somewhere- WAY DOWN ON POWER. lookout for 07 V6's while you are fixing this problem.
MAF not matched to 24# injectors? Horrible tune? Stock control arms? (I mean, what does "I have a tight suspension" really amount to? Are things beefed up, or just OEM stuff still in useable shape?) All of the above?
I thought I was doing bad when I only did a 15.0 in my stock H/C/I notch last summer. Yikes.
he said before he coulnt give it any gas or it would spin on the street tires.
if he had a good tire under the car and with the ability to give it WOT off the line i can only see the MPH going up
its too earlier to jump to conclusions saying he was down on power. its the uys first time, we only have a small list of mods and dont have his 60', 1/8th miles times and etc. we dont know much about his run at all.
but on topic
get a good tire and go back
a good tire makes all the difference
and what is this "tight" suspension you speak of what parts does it include exactly
