Need HELP Guys!
projectfiveo
347
My buddy just put a rebuilt 302 in his stang with new everything, well when he starts it up and lets it run it overheats like crazy...boiling water...so he changed the thermostat and it still does it...it has a new radiator and water pump...we cant figure it out?
I never thought about that, but how would the cap cause it to over heat?
Cooling systems are pressurized to increase the boiling point of water. If the cap is not keeping pressure then the boiling point of the water is lower.
Keep the cap off and allow the engine to come up to normal temp and see if the water flows through the radiator. If this is a new engine and the radiator gets clogged or if this is a old one then you may have problems cooling the engine.
Look for bubbles in the water too. The system may need to be burped, trapped air in the engine. This could be a sign of a bad head gasket too. Keep your eyes open and see what happens.
Allen
More info: 16 PSI in the system increases the boiling point about 48*F. This is key for a car running over 200*F.
A cooling system pressure tester would be helpful for you. What are the actual temps the car runs at, and what temp does it show when you hear boiling water?
A bad cap will generally allow you to hear the boiling after you shut it off.
Good luck.
