F3ZE is the numbers stamped on the head. Any body body know what kind of heads thoses are it also has AA stamped under that and the Number 22 Stamped and GT stamped on it. They dont have valves or springs yet should I port them?
:SNSign: I wont have to modify my exhaust to use these?
These Heads are better than E7 ?
Would you suggest porting them? and if I port them should I port the lower intake as well?
Absolutely, they're better than E7 heads. They're the same as the 93-95 Cobra heads, with larger combustion chambers for lower compression. Give them a port job, mill them, and throw them on. Knowing what kind of intake you're running would help, so we know if it's worth porting or not?
