In addition: There's a ratcheting function, which means the puter continuously checks the lowest reading the TPS reports. It uses this to set the baseline. So as long as the TPS is somewhere in the rough range of ~0.80 Volts to 1.20 Volts, it will 'zero' itself out (this is the adaptive ability of the EEC. This is built into the computer code to accomodate the range of sensor tolerances seen on the assmebly line).
And if the range is above that threshold, it should set a code. If and when it sets a code, that's the time to consider modification of the sensor mount to change the reading.
Now if you really wanna' start hosing with it, as long as you don't break anything (I think Grady discussed that possibility on this or the other current TPS thread), I *personally* don't have an issue with guys screwing with the TPS if it makes them feel better.
FWIW (point of comparison), mine sits at 1.19 volts (static) and seems to do fine.
Good luck.
