My stang has Eibach pro-kit lowering springs on it, with Steeda 3 bolt Caster & Camber plates. I also have a Steeda Strut Tower brace which looks like it ALMOST gets in the way of the C/C plates when adjusting for an alignment, but i dont think it does.
bottom line, I am getting a reading of -1.5* negative camber on EACH wheel in the front. And the plates are maxed out. I can't adjust them any farther....
Are there any other aftermarket C/C plates I should look into getting to get my camber back in spec?
I've debated porting some of the walls out of the steeda ones to make the camber adjust correctly, but thats last resort, i'd much rather just buy ones that will work.
Anyone else have similar problems?
...the car has a clean title and hasn't been in an accident to my knowledge, so I'll ad in nothing is bent out of whack. Just can't get the car past -1.5 negative camber. Its way out of spec and it has eaten my last set of tires a bit on the outside treads and now that i have new wheels and new tires on, i'd like to correct this ASAP.
- Jay
- Jay
