Problem with Gear Installation?
xlilzeex
45
Macomb, MI
Problem with Gear Installation? (Pic Added)
The guy installing my gears just called n told me he wont be able 2 use the 4.10's i gave him because they dont fit? My axle doesnt catch and wotn turn? I dont know what hes talking bout because i never installed gears? Anyone know what the deal is cuz at this point im pretty annoyed.:bang:
Where did you get the 4.10s? If they are supposed to fit into the rear of a Mustang then I'd say go to another place to have them installed.
it has to be for the 8.8 ford rear end because i bought them off this dude that actually had them for his mustang, so i dont understand why it wouldnt fit? im so frustrated at this point i havent had my car in like a month n a half. now hes telling me hes just gonna order a new bearing for my car and put in my old gears....:bang: ...i need to get this problem resolved and my 4.10s in there!
this sounds weird to me cause i have installed gears for a while now and never had that happen....either when he was assembling the gears he did not have the proper pinion depth and backlash set for them not to turn
"My axle doesnt catch" :shrug: What does this mean? I have not installed gears in a Ford 8.8 but have done GM 12 bolts and dana 60's. You install the ring and pinion and set all the clearances before the axles are reinstalled. If it is the ring and pinion that will not turn and the pinion turned before the ring gear was added he has to many side shims. If it is the pinion than like others have said he set the preload wrong.
here is what he claims to be the problem, when i turn my rear axle it wont catch onto the teeth and wont turn... i have a video too but its in .3gp?
I dont know what type of gears you bought but I bought Motive gears and my installer couldnt install them properly. He told me that they were factory made too close together and he could fit any shims in the rear. Ive been living with a constant howling and if I go past 90mph my engine light will come on and I have alot of vibration in the back. I now have to buy some other type of gear and have those installed.
http://www.2kgt.com/item.php?itemid=19
http://www.cartechbooks.com/vstore/showdetl.cfm?DID=6&Product_ID=2557&CATID=21
http://www.superstallions.com/tech/drive/gears/gears.html
FYI. Hope these help. :nice:
^ exactly. the gears i bought had the carrier/posi already with it. that could be the problem? could i just unbolt the carrier the 4.10's came with and just use my old posi/carrier?
the original owner probablt had 31 spline :shrug:
get FRPP gears alot easier to install
