Problem with Gear Installation? (Pic Added)
The guy installing my gears just called n told me he wont be able 2 use the 4.10's i gave him because they dont fit? My axle doesnt catch and wotn turn? I dont know what hes talking bout because i never installed gears? Anyone know what the deal is cuz at this point im pretty annoyed.
What does this mean? I have not installed gears in a Ford 8.8 but have done GM 12 bolts and dana 60's. You install the ring and pinion and set all the clearances before the axles are reinstalled. If it is the ring and pinion that will not turn and the pinion turned before the ring gear was added he has to many side shims. If it is the pinion than like others have said he set the preload wrong.
