my friend needs help
sn-95matt5-0
170
alright dont burn me for this.
my friend has a 88 iroc z. his dad is paying a MORON to reduild it and make some beast of a car. this guy has been ripping my friends dad off for the last year and a half. every time my friend goes to pick up the car it breaks down before we cn drive it home.
no that i've filled you in let me tell you wat happened tonight.
we go to pick the car up and it running hot. the guy says its because the starter is messed up and is running the ENTIRE motor backwards. all the acesories are spinning counter clockwise. other than that it runs fine. left me on the backwoods stretch of road and i stopped when i looked down and i was doin 110.(i know i shouldnt have been goin that fast and my friend was in the car with me and his dad was driving the iroc) but since all the acessories are running backwards its making the fan run backwards and isnt pulling cool air into the engine bay. SO, we change the starter. and guess wat. it doesnt help at all the motor is still turning backwards. so the guy says that it is the cam(WTF) he said marine motors run backwards so if comp cams sent him a marine cam and he put it in the car it would make the motor run backwards. i dont really see how it is possible for a motor to run backwards wouldnt it mess the tranny up. so he said he will get hm a new AUTOMOBILE cam for 150 dollars and that includes lifters. has anyone else seen i cam that is supposed to put out 500 rwhp on a heavy built chevy 350 for only 150 dollars, WITH lifters.
alright this is my explanation:
the moron bought a reverse flow water pump and has all the brackets running backwards on the belt. its the simplest explanation i can think of. and it sounds more realistic than the ENTIRE motor running backwards. and my biggest guess is he may be doin crap like this onpurpose to get some extra cash money of my friend.
well have any of yall heard anything like this ever happening?
o and for the record i did tell my friend he needed to switch to ford and i pointed out there is a very nice lightly modified 95 gt for saild own the road.:SNSign:
Well if the car goes forward in drive then the motor is turing the right way.
Now the cam has to be a car (not boat motor) cam otherwise I don't think it would run at all.
I think this guy just doesn't know how to set it up... probably not enough timing causing excess heat...
Anyone else have any thoughts?
hes running the wrong accesories drive on that motor for that year of that iroc there was some different belt drive configs (ie water pump rotation) for those years my friend had the same issue a while back the moron mechanic put the wrong water pump on the car even though it was bought for that year car there was a change mid year 1987 on the water pumps i guess correct me if Im wrong .I strongly recomend getting a different mechanic before he goes broke with that moron
It's possible the belt is just routed wrong too. If the belt wraps around the wrong side of the w/p pulley, it'll spin the opposite direction. Plus, it's a cheap trial and error test to see if it fixes it.
The cam suggestion makes no sense other than to fill the mechanic's (loose definition) pocket.
Scott
well they found out it was the belt that was routed wrong on the motor.
they went with a carb set up and it supposed to be a reliable 600rwhp that gets over 12 miles to the gallon.
i've been telling my friend to take it how and we'll get some books and work on it. but he says he doesnt want to fool with and rather this guy who is supposed to be the best builder in the state work on it.
he has a chevy 350 at his shot thats in a vaga. this car is supposed to be 1000rwhp N/A. is that possible? i figured it would have to be a big block to get close to that hp. expecially N/A.
