What all is needed for a radiator swap?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
I am ordering a new aluminum radiator friday, and I want to make sure I get everything I need. I have recently changed my pump, hoses, & t-stat. Im going to try and save the fluid, but Ill have a hose on hand just incase. Anything else Ill need? Besides the radiator. lol
Saving the fluid, are you mad?
Spring for a new jug you lazy bum. You are gonna give us Louisianians a worse rep than we already have. :-D
If you are feeling like a baller, distilled water doesn't leave those funky mineral deposits around like hose water does.
You guys never put a bucket under the radiator and catch the fluid? :shrug: I mean its not even 6 months old. lol
And I might just do the distilled water thing. Maybe Ill take a 5 gal jug of Kentwood water from work and use that. :lol:
Actually you are right, I will not keep the fluid, I dont want any of that crap from my old radiator getting in my new one. Maybe if i was changing hoses or something.
My car gets up to 250* in like a minute when I turn on the A/C. Ive changed everything except the radiator. So its the last thing. Im ordering it friday and I should have the $$ for the intake in a month or so.
Eric, if it's not a direct fit, you'll want something to mount the fan (no, do NOT use the pull through ties). And you might need to trim the shroud a bit (Dremel helps).
Good luck bud.
just to make sure, you have verified your fan does come on right?
does it get to 250 degrees at idle or while driving
Yea, it comes on. Im want to wire it to a switch too. And it does not matter if Im going 70 MPH. it will get hot when the A/C comes on. It should not get hot at that speed unless something in the rad is fugged. Which Im guessing.
