Need help. Critter chewed through nearly all plug wires. Need firing order for 69 302
Old Blue
58
I can't seem to find any of my books and it has been a while so i don't remember the firing order of the plug wires. can someone help me out?
also, there is an aluminum intake on it which shows the cylinders as 1,2,3,4 from front to back on the passenger side and 5,6,7,8 front to back on the drivers side. is this correct as well?
much appreciated.
as long as the cam is one designed for the early 302 then the firing order is 1-5-4-2-6-3-7-8. if the cam is a 351w or later 5.0 HO engine then the firing order is 1-3-7-2-6-5-4-8. the cylinder numbering on the intake is correct. i would use the early firing order first.
