I just ordered an MGW for my 00 GT and I figured I would change the trans fluid at the same time. Should I go with Mobil 1, Amsoil, or Royal Purple? Also how much exactly does it take?
Is there any additives I could put in for some preventative maintenance? I found this on the Lucas website:
"Lucas Transmission Fix
Lucas Transmission Fix is a non-solvent formulas that stops slip, hesitation and rough shifting in worn transmissions and completely eliminates most seal leaks. Use in any transmission for preventative maintenance.Use also in light duty manual transmissions to increase shifting ease and transmission life.
Key Benefits
* Contains no solvents
* Lowers operating temperatures and stops foaming
* Can be added to existing fluid without draining any out
* Effective in an extremely high percentage of cases"
Would that be good to add to whatever fluid I go with?
Key Benefits
