powermaster one wire alt help
superspec
78
ok i read several threads over the past few days but cant seem to find what im looking for. heres a pic to help i hope:
there are 2 plugs from the factory, one 3 heavier ga. wire, one 3 smaller ga. wire. the alt. has a spot for 2 wires plus the charge wire. do i simply hook up the charge wire to the battery with a fuse and leave it be or do the factory wires need to be plugged into the alt?
thanks for the help with my noob question.
please guys, surely it isnt that hard of a question to answer.
do i just leave the factory plugs disconnected or do i wire some up to the two spade terminals shown on the alt.?
What happened to the installation instructions or link to the manufacturer's web site?
Most one wire alts just use a fused 4 gauge wire from the battery side of the starter solenoid to the stud on the back of the alternator. Otherwise why would you call it a one wire alternator?
Leave to stock wiring along and just tape it up out of the way. That way if your fancy one wire alternator that no one knows anything about dies, you can go back to the stock alternator.
Wiring parts for any high current alternator:
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder @ $5.80 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
3/4 “ Black heat shrink tubing, 4ft length, $3.56
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=082-058
3/4 “ Red heat shrink tubing, 4ft length, $3.56
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=082-064
Pre-fab 4 gauge cables with lugs already on the ends are available in most auto parts stores. Look for the starter switch to starter cables.
I have an additional 4 gauge ground running from the power steering pump mount to the common chassis ground.
i know how to make it all work. i just dont know what to do with the factory plugs. im not your typical moron who cant put an alt on my own car. i simply dont know about the factory wiring.
one more thing... i would hardly call a powermaster alt a fancy peice of equipment. they dont list specific instructions on their site and all of my searching hasnt turned up the answers im looking for.
The whole point of a one wire alt is that its application is universal.
Is the power connection comprised of spade terminals? I hope not.
How many amps is the alt rated for?
Anyhow, one reason JR would have been asking questions is that with some one-wire alt's, you can indeed wire them to different degrees. For instance, you can use an ignition-excite, which I always think is a neat way to do it.
To answer your question since you know the rest:
You dont need to do anything with the OEM wiring except ensure it's insulated.
On the regulator plug, there are several wires. A is the remote-sense circuit, I is the ignition-excite terminal and S is part of the stator circuit.
On the other (2G) plug, there are two charge wires and another stator wire loop.
FWIW, I believe Powermaster does have install instructions on their site (I thought I was once trying to help someone and needed to access them).
Good luck with it.
Good luck with it.
yes, they do have instructions on the site but they are vague and very universal.
