Explain TIMING please.
ShortThrow50
923
Pa
I dont know where to start a search. I know how to time and all that but I hear about different crap. I only know how to time my car at the distributor.
Please explain all this different stuff like base timining, initial, total. I would like a better understanding. thanks
timing is the point at which the ignition fires on the #1 cylinder before it reaches top dead center. So if you say 10 degrees BTDC, it fires ten degrees before the piston reaches TDC. Base timing is with the little gray tab pulled(Can't remember what its called) and total is with it inserted and what you wouldrun on the street when driving.
how do you figure out total timing is really what im confused about. I have my distributor rotated to about 18 degrees timing and thats all i know about timing. how do you figure total timing?
All you need to know is to Time the mustang between 10 and 18 degrees with the grey plug pulled, then carefully tighten the dizzy back up, and reinsert the plug :nice:
Concept: the combustion process always takes the same amount of time, no matter what RPM you are turning.
Some further explanation will help. Keep in mind that the numbers are for educational purposes only.
Since the combustion process is supposed to be complete before the piston gets too much past Top Dead Center (TDC), the faster the engine turns, the sooner the combustion process must start. This means the ignition system must fire sooner at 3000 RPM than it does at 1000 RPM for maximum efficiency. Hence, the requirement for spark advance.
Total timing is usually around 34-38 degrees at 3500-4000 RPM. The computer's internal tables have the spark advance data in them based on RPM, load, air temp water temp, throttle position and other factors. The computer has 22-30 degrees of advance in its program. Use 14 degrees base timing and the computer adds spark advance to come up with a total timing figure. . At WOT, the 14 degree base timing gets added to the computer's WOT timing figure of 24 degrees for a total of 38 degrees.
Think of the movement of the crank as a circle, 360 degrees in it. Bumping the timing 2 degrees foward means the engine fires while the crank is in a position 2 degrees earlier than where you adjusted it from. The crank position dictates where the piston tops going to be.
Here it is from an Aerospace & mechanical Engineer who took IC engines masters level.
If flame propogation, fire, was instant then you would put your timing on 0deg. It would have the best efficiency. Different fuels have different propogation time and pressure makes it faster b/c Pressurexvolume = Mass x 0.821 x temp. means that a built stroker gets 10deg of timing vs. 18 with a stock 302. Excessive air pressure and bulcy iron heads cause spark knock.
Now, with your plug out of the dist., you're are looking at initial timing which is the 10 to 18 normally. Initial means no computer involvement....
Total means wide open with max vaccum/computer advance and lowering volumetric efficiency in which a motor optimally burns its fuel at high levels off (which is why 4500 rpms is where max torque is often made. So you have to burn your fuel faster so that it burns before the exhaust valve opens or the pistion is going back up.
Hope this is not just runon and that it helps.
