Cold start still sucks!
LaserSVT
3,548
233
I am still having problems with my cold starting. I have to give it gas or it will die and it will make a couple muted "pops" like little backfires I can hear through the intake. No codes, 700 rpm base with IAC and distributer plug removed, new IAC, new ACT, ECT is fine, 14 deg base timing, cleaned mass air and t-b. The IAC is from Autozone and did not say to mount upside down. It will also "hunt" idle rpm until its warm (after 2-3 min) What am I missing?
If you read the "Surging Idle Checklist carefully you will find that a cone filter under the hood is a big no-no. The disturbed airflow through the MAF causes all sorts of problems. Sometimes clocking the MAF helps.
See "Surging Idle Checklist for help with all your idle problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Thanks, read that sticky till I was cross-eyed, I was under the disillusion that sensor was ignored during cold start. When my hood shows up in a couple days I will be using the through the hood intake and see if that solves the problem, if not I guess I will locate a stock mas air and go from there. Will keep posted.
I just flipped my IAC upside down and she fired right up and idled well with no stalling, my high idle time is a little too short so I guess I would have to reprogram my ECU for that, but the problem is I cant leave the IAC upside down because the plug hits the hood. How does everone else flip the thing and get it to clear the hood?
