Anyone know how to wire an ignition setup like this? Its for a 86. This is for a race car and I don't necessarily need the keyed ignition.
If anyone can provide a schematic, that'd rule, because we need to UN-do the push-button start some fool rigged up on Frankenstang's '86 'vert. You still have to put the key in and turn it forward to the run position, but the push-button is what engages the starter.
I'd imagine all it really would entail would be doing something similar - rigging a bypass momentary switch that activates your starter - and then finding a way to rig the ignition to be switched on/off from the run position without a key. You could always just do away with the lock/tumbler altogether and just reach under the column (with the shroud off) and manually move the ignition switch forward/back, but it would look horribly ghetto. And besides ... do you WANT your car to be stolen, or something? Having a functional key/tumbler would seem liek the first line of defense against thieves, to me...![]()
do you still want to turn the key for everything else??
I was thinking of using two switches for the run and acc in the same manner. Just flip all three and hit the button and go.
Thanks for the PDF!
since it's for a race car,
if you aren't running a computer or A/C. do you need lights??
i'd rewire it from scratch. painless wiring has harnesses to get you going. that way you get rid of all the excess wiring.
