intake setup
pacesco
24
ok, here's what I have.
347cui
scat forged steel crank
h-beam rods
balanced
RHS cyclone 200/64 heads
Comp cam duration @ .5 lift, intake 224 exhaust 236
10:1 compresion ratio (should be able to run pump gas)
AODE trans
2800rpm stall converter
125hp wet zex nitrous kit to install
here's my question...:shrug:
what intake set up should i run? i was looking at the BBK SSI set up??? also what size injectors, fuel pump, and should i change the fuel rails and pressure regulator? should i change the computer, what is the best one to go with?
any help on this would be great...:)
brian
Your not gonna Extrude Hone a GT40 a whole bunch...The tubing is thin stuff as it is...Something tells me the GT40 is not the best choice for your set-up...and the BBK is kinda so so power wise to the normal 5.0 intakes..Both look nice but they're not the best performers..
I would think the stock ECC and an SC would do just fine...depends on your budget??
