Camshaft Markings? ?
asecretfile
228
Next door neighbor bought a new Xcam today...the box says X303 and so does the paper insert that comes with it....but on the actual camshaft it says..
M6250F303...but the F is stamped really lightly and directly above that lightly stamped F is a hard stamped X...could that have been a marking error, because this cam was bought new as supposedly an X? Hopefully that hard stamped X right above it is what it truly is lol?
TIA :nice:
Grind number for the X cam is: M-6250-X303
Grind number for the F cam is: M-6250-F303
Not much room for error:)
When you put the cam in the block (if you want), you can check the peak lift numbers with a dial indicator.
.512" for the F cam and .542" for the X cam.
More likely than not, it is the X cam with the other 'consistencies' you got (box/paper).
Good Luck!
Good Luck!
yea I agree..the grind number stamp was somewhat distorted, and Ive seen FRPP stamps other times before and they were easy to read... :shrug:
Id imagine its what the box and the paper insert says seeing as how that X was deep stamped directly above the barely stamped F
The M6250 letters dont even line up with the X303 part...off centered lol
