Need some help with broken bolt before I snap
pwcracer
347
Hastings, MN, USA
I was installing my timing cover today, enjoying life when I noticed the bottom left bolt won't go it. I remove the cover and noticed the jackhole who sold me my shortblock failed to mention he snapped off the timing cover bolt in the hole.
No big deal I thought, I drilled a hole in the bolt and ran a bolt extractor in it, and snap, the extractor snapped in the bolt.. Now I am stuck! I can’t drill it, as it's hardened like a samurai sword, and I can’t really get in there to weld onto it.. (I already tried this several times, and only messed up the surrounding area. I have a couple of ideas,
If this is the side that requires a dowel, like the other, I was going to weld in a dowel.. I was then going to cut the head off a bolt and weld that into the dowel.. I would hopefully have a stud that I could throw a nut on and be done with it.
My second thought is to go get my dad’s plasma cutter and try and blast a hole in the bolt, and then retap it..
Any other ideas?? Could use some help, as I have been working on this the past 3-4 hours.
By looking at the picture, it appears to be out...so the machine shop is a good idea, put the 'pressure' on them. They may have dealt with worse...
It just depends on how much money is worth your time and stress level...:)
Good Luck!
There is a drill bit that will go through the extractor. I believe it is carbide but I'm not sure on that. It is about 15 dollars a bit though. I would try that first.
Otherwise if you take it to a machine shop they can use a special tool made for removing broken taps from holes which kind of works like a welder and basically vaporizes the broken bolt using electricity. At least that is what I was told. Either way if the carbide drill bit doesn't work then I would bring it to a machine shop.
Plunge edm. basically you burn the bolt out with electricity. Very effective way especially if your dealing with some hard stuff (in this case the extractor.)
