gcomfx.com
Max rpm is 6500, right in my cam spec's.
Is the 6,500 rpm the top of your cam's powerband (example: 3,600-6,500 on cam sheet, but you shift it 3-400 rpm higher (like most), or is 6,500 rpm your shift point?
I see GRN is trying again. Dude I bet there's plenty of girls that could whoop you in a track race AND a street fight, lol.
Yeah, I mentioned the C&L in my thread. It read hotter than the black intake did.
I wouldn't look at more gear if you ever want to spray the car. I ran across the traps well over 6,000 on the 75 shot. I don't know if I have the tire for the 125 shot. Good thing my slicks are taller than my drag radials.
BTW - when are you going to a 1/4 track?![]()
A custom cam designed around a bigger exhaust is key, if replacing exhaust. As long as Mr. Curtis knows your combo, you'll be good to goYou can lose power going with a 'bigger exhaust' or you can gain with a 'bigger exhaust', depends on the valve events.
What are the PS3 springs from Ed good to as far as lift is concerned? Are the PS2's .600? This is just speculation...
Too much spring?
Stage 1 cam in a 347...lol.
juiced - You running full accessories?
. Except for the fact i cant even get my car to run anymore
I don't agree at all with the anything over 1hp/cube rule being not too streetable. I'm probably in the 375-400rwhp range with my mild 347 and its perfectly streetable, unless you have a bleeding hole between your legsMy sig describes it perfectly. I do think it would scare pokageek though
Its probably just too conservate of a tune being the culprit. I would however consider investing in a holley intake, custom cam and more gear down the road and really make this thing a 331![]()
Bleeding hole there?Don't try and e-thug me just because you're afraid of fast street cars. Stop responding to me, this conversation is over. If it continues, the mods WILL be notified.
j/kThe PS3 springs are rated at .630" lift, as far as accesories, I only deleted the smog pump and EGR so i still have P/S and A/C.
Let us know when you find out the a/f and total timing.
and totally forgot to ask about the timing and A/F Get the cable off ebay. $4 shipped vs. $40 at Best Buy.![]()
