Thumper E7s or GT40p?
What heads would you recommend for a daily driven street car? I was initially interested in the trickflow street h/c/i, but $3000 for the kit, a tune and supporting mods is out of my budget right now (I know its a good deal, but its still out of my price range) Ive been looking at cheap iron bolt on alternatives recently, and these two seem to be the most popular.
Im looking for at least 300 flywheel hp, which I think is 260 rwhp. I want to have confidence rolling up to new edge 4.6's, the common ricers, and get into lt1 and pre-03 cobra territory. The car is a daily driven 95 gt, so driveability is the first priority, a close second is a torquey powerband (I hear thumpers heads are good for this). I Also hear the stock HO cam isnt too bad as far as performance goes, so if I left it in that would keep the computer happy and save the expense of a cam swap and tune.
What are some pros and cons of each setup? Please dont rag on the iron heads, I know aluminums are superior in every way, but they are too expensive right now. I hear of people breaking the 12s with thumpers heads and explorer top ends, please enlighten me :cool:
i'd do thumper e7s, stock HO cam, and a tmoss ported lower intake and port match the upper and etc and do some bolt ons like TB and pullies. will SOUND STOCK, ACT STOCK and run good.
will make 260 rwhp fairly easily and will be a SLEEPER. you can whoop someones ass and tell them its a stock engine, if they dont believe you, pop the hood start the car, itll be a stock engine but on steroids lol
plus it will have great driveability, excellent low end and wont cost too much.
Point less gt40 heads are cheap. About $360.00 at auto zone and advanced. That is the set! Say you have a 96 or 97 ford 5.0 explorer.
Use your stock E7s as a core. Than have thumper port the GT40 heads.
The store will never know the difference.
no they dont. ive seen a blown up 302 turned in as a core for a 351
Last time I checked, the thumper heads cost some good dough. Also, that HO cam isn't my first choice for a cam. I re used my HO cam in my gt40p setup, and I'm VERY sad I did. It doesn't make power past the low 5's, where my bro's car with a tfs cam makes power and pulls hard up to 6k,.
As mentioned, buy the entire explorer engine. It'll come with the gt40/p heads, the explorer intake, and only set you back $600 give or take a couple of hundred. That leaves you quite a bit of dough left over to port the gt40/p heads and get some bolt on's.
I would look at f303 cam. it can make 1000hp wheel in turbo setups
This is my reasoning exactly. Sure i can pick up some used gt40s off an explorer, but then who knows what kind of freshening up they will need (more $$$ and hassle) and apparently thumpers e7s still flow better and with smaller ports (high velocity = killer low end = fun street car)
I know I could get more power with a cam swap, but this is a daily driver and I dont want to open a can of worms with tuning issues and driveability. Maybe at a later time when I want more power I can look into a custom grind with daily driver in mind.
So I dont know too much about tmoss port work, but thumpers heads and tmoss lower seems to be a popular combo. 260 rwhp is a good number, enough to take stock/bolt on 4.6's, kill pesky rice, and get into lt1 territory. So from top to bottom: Stock maf, larger tb, port matched upper, tmoss lower, stock 19# inj, thumper e7 heads and springs, 1.7 roller rockers (will these work well with the stock cam?), stock HO cam and pushrods, full exhaust. Opinions?
Quick question, would these heads kill my gas mileage, or should it remain close to stock?
I'm still telling you, it's a waste of money. Last time I checked, thumper heads were $600. $600!!! OUCH.. Does that include shipping too on those heavy beasts?? No offense against thumper, as he seems to have a legendary rep, however that's a waste of cash in my book. A used set of gt40's can be had for $200 easy. Take them into a local shop and have them rebuilt for $75 a side, and some mild port work on top of that, and they'll outflow any thumper e7's for the same price.
As for driveability issues with a cam, well there are none. So long as you go with a small cam like the tfs 1, and have mass air, you'll have NO issues. I'm simply trying to help you with my mistakes. The stock cam makes good power, but is wortheless imo once you start bolting on heads and intake.
Used gt40s can be cleaned up for only 75 bucks, including a port? I heard that some places charge around $300 to freshen up old heads, I dont know whats all involved, but maybe im hearing incorrect information :shrug:
Anyhow, thumper recommends the B cam with his heads, something to do with complementing the intake/exhaust flow of the heads. Everyone seems to think the B cam is outdated, so the trickflow 1 might be better then. Will gas mileage take a dive with a cam, or is this a misconception? What kind of power increase could I expect from subbing in a tfs1 for the stock cam?
i was going to go with thumper heads but the shipping cost and the cost of shipping my cores back make them impractical. i have about $400 total in my gtps (heads, machine work, new springs)...if i could do it over again, i'd just go with the tri state cylinder heads gtp's for $598, with no core. they have over size valves an 5 angle valve job. i just couldn't put 7 or 8 hunder in a set of E-7's.
I was quoted $75 a side for a rebuild of the heads if no hard parts need replacing. This is with NO port work. I was simply pointing out, that after his price, and what you'll pay for shipping, you could secure a local set of gt40/p heads, have them worked, make more power and still come out ahead in the long run.
As for cam combo, if you get the thumpers, I'd recommend whatever he does, I don't have experience with his heads.
If you where going to spend that much on there p's just buy there aluminun ones. There $850 shiped to your front door.
http://www.tristatecylinderhead.com/catalog/product_info.php?cPath=41&products_id=29
And as far as needing a tune with a cam and bad gas mileage. I was running the TFS 1 cam with 1.7RR with port E7's shaved .030 and was geting 16mpg, and i ran it hard all the time.(Watch out for the stock rods.)
I think you would be better of buying something new. Buying used heads is sketchy. I bought a set of used gt-40 originals for 200 bucks. I brought them to the machine shop and had a LOT of work done to them and spent about 500 bucks on them. I had the spring perches machined, 3 angle valve job, new valve guides and viton valve seals, and i had them milled 30 thou.
In hind sight...i wish i would have just waited and bought new eddy's, TW, or AFR's. The car is quick though. Definitely enough power to beat up on 4.6's all day.
The thumpers are a great deal IMO, thats why I run a set. He does an awesome job on the porting and all the valve train is brand new.......you don't have to buy used crap and hope it works like they said it would.
I installed them with a TFS1 cam advanced 4* for low end grunt and a Tmoss lower intake. For the money I spent I amvery happy with what I have, plus I can still pop the hood and show off my stock engine.
Thumper will prolly post here sooner or later
That's almost exactly what I'm doing over the winter. Mine will still be speed density, but every other part is what I've got.
