Well my 93 notch is still overheating. It has a new radiator, new 180 degree thermostat, full of antifreeze w/ water wetter. Stock fan is back on the car.
Drive for a few miles, come back and sit in driveway, or drive thru, or anywhere idling and it starts overheating. Ran about 211-215
yesterday idling after a 15 minute run. I had the a/c on. I turned the a/c off and it dropped just below 210 which IMO is still too hot for this car. It stayed there afterward.
As some of you may remember I had a Taurus fan on it which worked decently but not perfect- car was running 205 and with that fan should have ran 180-190, but the fan had constant issues. So I switched to a flex fan and it started overheating again, so I switched back to the stock fan and it still overheats (210+).
The only thing that has been suggested so far is to change the water pump. Anything I might be missing? The car has an underdrive pulley on the crank.
Thanks,
Jon
yesterday idling after a 15 minute run. I had the a/c on. I turned the a/c off and it dropped just below 210 which IMO is still too hot for this car. It stayed there afterward. As some of you may remember I had a Taurus fan on it which worked decently but not perfect- car was running 205 and with that fan should have ran 180-190, but the fan had constant issues. So I switched to a flex fan and it started overheating again, so I switched back to the stock fan and it still overheats (210+).
Thanks,
Jon
