spline question?
inphiniti
412
Providence, RI
never messed with a rear end so im in a bit of a question asking mood... please bare w/ the stupid questions.... LOL
what comes stock in a 8.8 rear?
what does a spline do?
and what would the difference be of me upgrading my Track-Lok, and axles to a 31 spline?
whatever info u guys can provide... would be very helpful! thanks fellas!
If you upgrade the carrier you must upgrade the carrrier. One fits into the other.
The splines on the carrier side gears mesh with the splines of the axle.
My understanding is that the other difference between the 28 and 31 spline axles is that the axles are larger diameter (splines are the same size but more of them)...
As for if it is worth it to upgrade... that is hard to say. A lot of guys run around with 500 HP and no issues...
The stock 28 spline setup really seems like a hit or miss thing. I've seen/heard of cars snapping the axles with 300rwhp and Nitto DRs; on the other hand, I put a solid out of a 94 GT with 3.73s in my old 04 Cobra. I didn't baby it and put over 25k miles on it, some of that with DRs, and never had a problem. The car it came out of was my friends HCI 150 shot 94 GT that he launched off the limiter on slicks, spraying out of the hole. Stock axles and diff. That said, I will be building the rear in my '94 with 31 spline stuff for peace of mind, if nothing else.
I don't think 31 spline axles are really that much stronger than 28. The bigger difference is that the stock axles have machined splines where as good aftermarket ones (28 or 31 spline) will have cold rolled splines which make them much stronger. True you loose ductility with the cold work but hey a twisted spline is prolly just as bad as a broken one.
